Serverumbau
Bearking
11
Schönen guten Tag zusammen,
ich habe ein etwas ungewöhnliches vorhaben. Und zwar möchte ich meinen alten Desktop-PC zum Server umbauen / als solchen Nutzen. Derzeit habe ich einen PC daheim rumstehen, in dem ist ein P6T SE mit mit einem Xeon 5670 verbaut. RAM ist laut System-Info 12GB:
Code:
*-firmware
       description: BIOS
       vendor: American Megatrends Inc.
       physical id: 0
       version: 0908
       date: 09/21/2010
       capacity: 2MiB
       capabilities: isa pci pnp apm upgrade shadowing escd cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb ls120boot zipboot biosbootspecification
  *-cache:0
       description: L1 cache
       physical id: 5
       slot: L1-Cache
       capacity: 384KiB
       capabilities: internal write-through instruction
       configuration: level=1
  *-cache:1
       description: L2 cache
       physical id: 6
       slot: L2-Cache
       capacity: 1536KiB
       capabilities: internal write-through unified
       configuration: level=2
  *-cache:2
       description: L3 cache
       physical id: 7
       slot: L3-Cache
       capacity: 12MiB
       capabilities: internal write-back unified
       configuration: level=3
  *-memory
       description: System Memory
       physical id: 3a
       slot: System board or motherboard
       capabilities: ecc
       configuration: errordetection=multi-bit-ecc
     *-bank:0
          description: DIMM 1333 MHz (0.8 ns)
          product: ModulePartNumber00
          vendor: Manufacturer00
          physical id: 0
          serial: SerNum00
          slot: DIMM0
          width: 64 bits
          clock: 1333MHz (0.8ns)
     *-bank:1
          product: ModulePartNumber01
          vendor: Manufacturer01
          physical id: 1
          serial: SerNum01
          slot: DIMM1
          width: 64 bits
     *-bank:2
          product: ModulePartNumber02
          vendor: Manufacturer02
          physical id: 2
          serial: SerNum02
          slot: DIMM2
          width: 64 bits
     *-bank:3
          product: ModulePartNumber03
          vendor: Manufacturer03
          physical id: 3
          serial: SerNum03
          slot: DIMM3
          width: 64 bits
     *-bank:4
          description: DIMM [empty]
          product: ModulePartNumber04
          vendor: Manufacturer04
          physical id: 4
          serial: SerNum04
          slot: DIMM4
          width: 64 bits
     *-bank:5
          product: ModulePartNumber05
          vendor: Manufacturer05
          physical id: 5
          serial: SerNum05
          slot: DIMM5
          width: 64 bits
Dies ist etwas seltsam. Auf den ersten beiden Bänken ist jeweils 4Gb 1600er, auf den anderen beiden Bänken ist 2x8GB 1600er. Hier scheint er beide nicht korrekt zu erkennen. Das er die 8er nicht richtig erkennt ist klar, da das Board nur 4GB Supportet. Aber 4x4 wären eigentlich 16gb. Kann es sein, dass ich DR verbaut habe aber nur SR unterstützt wird? Welches RAM würdet ihr empfehlen um auf die vollen 24GB zu kommen.
Darüber hinaus befindet sich das PC aktuell in einem normalen PC Gehäuse. Ich würde ihn aber gerne im Rack unterbekommen (Das ich auch noch brauche). Könnt ihr ein Gehäuse empfehlen, dass möglichst günstig ist und in ein 19 Zoll Rack passt. Schön wäre, wenn es Festplatteneinschübe hätte.
Ein Rack hab ich bisher nicht, habe aber ein 21HE Rack im Auge. Da sollte ein Patch-Panel, die Steckdose, ne NAS und 3 Server rein gehen und es müsste noch Platz sein für Geschichten die mir irgendwann noch einfallen. Sogar falls ich 4HE Gehäuse für die 3 Server benötige.
Aktuell soll darauf betrieben werden:
  • EsproCRM
  • PiHole
  • Elastic-Stack
  • HomeAssistant
  • Oracle 19c (Läuft schon dort)
  • Unifi-Controller
  • DNS-Server
  • Vermutlich Gitlab
    Vermutlich Artifactory / Nexus
  • Vermutlich meine selbst entwickelte Software
  • Ggf. ein Proxy
Mit 6 Kernen / 12 Threads und 24Gb RAM müsste er das eigentlich packen. Außer Oracle läuft derzeit alles auf meine Desktop-PC in HyperV Maschinen.
Was haltet ihr von dem Vorhaben? Was sind eure Empfehlungen?
Schönen Sonntag noch :)
Bearking
11.805
wenn ich das jetzt richtig seh ist in slot 1 2gb verbaut, slot 2 ebenfalls 2gb, in slot 3 und 4 jeweils 4gb was in total 12gb ergibt wie es auch angezeigt wird, slot 5 und 6 sind leer
du kannst einfach ganz normalen ddr3 ram verwenden (am besten gleiche taktung und selber hersteller), oder mal bei asus in der qvl nachschauen falls du dich hier schwer tust
zwecks den server nas sachen etc verlinkt ich die hier mal @TheSupercomputer, @HardwareFlix und @Skyfay die dir hier deutlich besser helfen können
Reactions: Skyfay
HardwareFlix
Feb 16, 2019
8.215
5.789
Code:
*-firmware
       description: BIOS
       physical id: 0
       version: 0908
       date: 09/21/2010
       capacity: 2MiB
  *-cache:0
       physical id: 5
       slot: L1-Cache
       capacity: 384KiB
  *-cache:1
       physical id: 6
       slot: L2-Cache
       capacity: 1536KiB
  *-cache:2
       physical id: 7
       slot: L3-Cache
       capacity: 12MiB
  *-memory
       physical id: 3a
       capabilities: ecc
     *-bank:0
          physical id: 0
          serial: SerNum00
          slot: DIMM0
          width: 64 bits
     *-bank:1
          physical id: 1
          serial: SerNum01
          slot: DIMM1
          width: 64 bits
     *-bank:2
          physical id: 2
          serial: SerNum02
          slot: DIMM2
          width: 64 bits
     *-bank:3
          physical id: 3
          serial: SerNum03
          slot: DIMM3
          width: 64 bits
     *-bank:4
          physical id: 4
          serial: SerNum04
          slot: DIMM4
          width: 64 bits
     *-bank:5
          physical id: 5
          serial: SerNum05
          slot: DIMM5
          width: 64 bits
  • EsproCRM
  • PiHole
  • Elastic-Stack
  • HomeAssistant
  • Unifi-Controller
  • DNS-Server
  • Vermutlich Gitlab
  • Ggf. ein Proxy
Bearking
Moin. Grundsätzlich rate ich davon ab, CPUs aus dieser Xeon-Generation noch in Servern zu verwenden, aufgrund des langsamen RAMs wovon so manche Anwendung profitiert, der vergleichsweise sehr hohen Leistungsaufnahme und dem fehlenden Support für moderne Techniken wie USB 3 oder M2.
Sollten das alles für dich keine KO-Kritierien sein und die Leistung ausreichen, kannst du natürlich auf solch eine Plattform setzen.
Günstige 19“ Gehäuse gibt es bei Inter-Tech, wahlweise mitreden ohne HotSwap in allen Größen und Formen. Ich würde mindestens auf ein 2U Case setzen wenn die Lautstärke keine Rolle spielt.
Für die Backplane bei den HotSwap Modellen benötigst du noch ein passendes 8087 SAS Kabel.
Je nachdem welchen Hypervisor du verwenden willst, könnte es mit dem RAM durchaus eng werden.
