Weshalb habe ich nur 2400MHz? Was heißt eigentlich c14 c15 c16?
Hamit20
44
TheHardwareFreak
11.929
9.244
Für dein Board:
Boot into the BIOS by pressing [DEL] or <F2> if you PC starts up during the post procedure.
Switch to Advanced mode by pressing <F7> on your keyboard.
Go to the Ai Tweaker section of the menu, and change the AI Overclocking Tuner to D.O.C.P Standard.
At the D.O.C.P. choose the appropriate XMP profile for your Ram modules. (it could be one and it could be more profiles)
If you did that, go to the Exit menu and select Save Changes & Reset or just press the <F10> key on your keyboard.
After you PC reboots, the new Ram frequency values should have been applied. :)
Quelle: https://pcpartpicker.com/forums/topic/300458-how-to-set-xmp-profile-on-asus-b450-f-motherboard-bios
Hamit20
44
Xmp Profil nicht gefunden aber docp schon und ....
